Hello, I see a setting for notifications in the app. When I go in there, I have 3 sliders. Notifications, Motion events and sound events. I do get in app notifications, but nothing more. I see on various websites people talking about push notifications, texts, etc…the only way I can see the events is to go into the app and look at them. I dont see a way to “send an external” notification out of the app. I do not have the subscription, nor do I have a micro SD card yet. Am I missing something?
You need to go into android app settings for the app and enable notifications. When you first install the app it asks you to do this but it is easy to skip. Once you do that you should start getting notifications. Note that the sound probably will just be the system default sound, the sound from the app seems to not pass through to android anymore, so just pick an Android system sound that works for you.
If you’ve tried multiple different sounds in the app, you’ll have several “wyzenotification” options in the android notification settings, Just turn them all on, then after you’ve gotten a few, one of them will say “about x per day”, that’s the one you want to customize the sound on. Or you can just put the same sound on them all if you don’t want to wait.
Sounds right, thank you! The in app notifications were indeed off.
