This is May 10 2022 and just noticed that there’s a siren on my Pan 2 cams. It never showed before. And like the poster above it can not be turned on as a device trigger. So if one cam spots motion I can’t have the pan 2 play the siren athough I can manually make the siren go . I’m not seeing a solution on this thread though. What is going on here?
Did you look for an action rather than a trigger? If you want to turn on the siren that’s an action triggered by motion detection on the other camera.
yes it is not there. I think several others have reported the same issue but as usual Wyze is not doing a thing to fix it.
