No Wyze cam V2 on Amazon?
No wyze cam on Amazon? went to get 2 more and they were out of the cart and can not find in the search, can find the Pan Cam but not the standard wyze cam, am I missing something ?
I don’t think you’re missing anything. I only saw the Pan. Even a google search and clicking the Amazon link from the search results says “Page not Found”
Buy directly from Wyze. Support them that way. The cost is essentially the same.
Maybe Wyze Cam v3 is coming out?
If so, it would be their most stealth product yet. Haha. I don’t think so. The status on the roadmap is still “maybe later” for the V3. I think they’re busy getting the outdoor camera ready for primetime, but that will be a separate product – not a replacement for the V2.
Not sure why it’s off Amazon, but I’m sure it will be back soon.
They were there yesterday, then gone today.
They’re back!
Yep, In Stock Now! :partying_face: :partying_face:
Wyze Cam 1080p HD Indoor Wireless Smart Home Camera with Night Vision, 2-Way Audio, Works with Alexa & the Google Assistant (Pack of 2), White - WYZEC2X2 https://www.amazon.com/dp/B07G2YR23M/ref=cm_sw_r_cp_tai_dlNhEbJHKKNQC
Ya, just ordered a 2 pack :grinning:
