The Wyze app doesn’t show September in the calendar view for the Wyze Sprinkler. Shows August and skips to October. What is going on?
@Nameless
Good catch, I was able to verify this on mine and I will report it to WYZE, you should also if you haven’t yet
I submitted a case to support and was told to delete my sprinkler and readd it. Nope. Then I’ll spend an hour trying to get it back.
