Has anyone tested the battery on these left on continuously? Results?
Welcome to the user-to-user forum, @emeralds! ![]()
If you use them powered on continuously, it had better be as a flashlight! I haven’t tested that, but I wouldn’t expect them to last long, probably not over a day. They are really only meant to be on with motion, and even then I wouldn’t recommend pairing them, as that can drastically shorten their life. Mine light up fine one at a time as I walk.
All that said, my bathroom lights last about 2 months, and my garage light (stuck to the side of my water heater so I find my way to the car door) lasts 6 months. It’s all about how many times a day they come on.
I’ve read some good but also a ton of bad reviews for the Wyze night light system.
Pros:
Link multiple together
Cons:
Bad mounting magnet
Battery life
Doesn’t connect to the Wyze app
For any users that have this system, is it any good or is it a headache? Are there any other alternatives to it that run on battery and can daisy chain together?
Please don’t cross post ![]()
