My camera always shows video upside down
One of the cameras I installed was always upside down. Do I have it installed incorrectly or is there a way to change the settings?
Welcome @popewayne
Go to the settings of the camera and toggle to 180 degree option:
  • Start the live stream
  • Tap on gear at top right
  • Tap on Advanced Settings
  • Then Tap on Rotate image 180 Degrees.
Then back out and it should be ok.
Thanks for the quick response. I think all is working well now.
I have one of my v3 cameras mounted upside down. When I made a sheet metal L bracket, I mounted it a little too high as my rain gutter was in the way.
Attaching my v3 to the bottom side of the metal bracket and flipping the image 180 degrees in settings works without me having to move my L bracket.
