Multiple keypads
I should be able to have multiple keypads for the alarm system one at the front entry as well as at other entries this way when the at home alarm is set and I want to go out the back door I do not have to go all the way to the front of the house where our main panel is located to shut up the alarm.
[Mod Note]: Post was moved to this category as your request is satisfied by existing functionality.
You can have numerous keypads:
The screen shot shows 2 but can a 3rd be supported? Im looking to remove my VIVINT system but i require 4 keypads.
You can add as many keypads as you desire. Keep in mind that the hub supports up to a maximum of 100 sensors and keypads:
