Multiple Camera Timed Playback
I’m setting up some cameras at my work and i would like to be able to playback multiple cameras at the same time, i’m replacing my WatchDog DVR that has this ability and it helps when tracking situtions at work.
Any thoughts on a work around for this?
You can view multiple cameras live at the same time if you put them in a group, but you cannot view multiple recordings.
You could consider looking into a solution like TinyCam, or Wyze docker bridge, though they may require a little bit more technical knowledge.
