I live next to a very busy highway and my cameras are picking up vehicle traffic. If I purchase the Wyze motion sensors will they take place of the motion/person detection feature on the cams and turn on/off recording by sensor instead?
I know you can set up rules for your motion detector, and some folks on here have used masking tape to cover half of their motion detector so it will only detect near motion but won’t see far off motion, so I bet there is a way to achieve what you want. Not exactly sure from your post fully what you hope to do, but I suspect it can be done. They do not “take place of” the motion detection, but they can be set to detect motion. You will need a Wyze cam and a bridge to use the motion detectors or contact sensors. The bridge plugs into the cam and connects the sensors to your system.
