Does anyone know of a way to get motion detection for ducks? I set up 2 cameras near wood duck boxes, hoping to catch babies jumping from the box after they hatch. I have seen mama come and go, but she is not triggering the motion detection, so I have only seen her by luck. I have both the PanCam and the V4. Both cameras are detecting other animals, I got a recording of a raccoon trying to get into the box, but the duck does not trigger an alert or recording. I think I may have missed the babies over the weekend. Also, there is no way to go back and easily search the SD card. Is there a way to watch footage in higher speed?
Thank you.
Welcome to the Forum, @jd5503!
I didn’t see anything in your post about whether or not you’re using a subscription (Cam Plus, etc.), so I don’t know if you have access to Smart Detections (e.g., Pet) and if that’s how you’re capturing events like the raccoon. Sharing information about that and about how you have sensitivity set would be a good place to start.
Not currently, but that’s been requested in the Wishlist:
You can visit that topic to Vote above the initial post and then share your ideas and use cases in the comments to show your support for that request.
Which Cam Pan do you have? Is it Cam Pan v3 ?
