Monitoring delay time setting not showing up
So I can no longer change delay for exit and entrance in home monitoring settings , and I have the subscription soooo is there away to fix this? If I arm woth my phone the system will set alarm off right away if I use the pin pad then it still will give me the delay time I set before but I can’t access it in settings to adjust
I do have subscription
