Micro USB cable length
I elected to change to 2A power adapters. Most of my v2s have a Sense bridge plugged into the back, run 16.5’ or greater cables and the cams, cables and power adapters are exposed to extreme cold during the winter.
I am happy to report that the cables that I bought work just fine. They fit actually very tight much tighter fit than the original Wyze cable fit.
https://www.amazon.com/dp/B06XYH75NQ/ref=cm_sw_r_cp_api_i_nr9kEbCZFZG48
