I tried different sd card and format it different way but Wyze still couldn’t see it.
I got mine working by format the sd-card using Canon camcorder first, then once Wyze see it thru the app then I format it again.
What different way would that be?
I inserted the sd-card to my Canon camcorder and format it from the camera on-display itself.
Before that… you said “I tried different sd card and format it different way but Wyze still couldn’t see it.”, and I am just wondering how you formatted it before putting into the Canon?
I tried exFAT and FAT32 using Windows machine.
Did you try to format it with the Wyze Cam before trying it in the computer?
Yes, it’s not detected by Wyze.
That is odd. But I am glad you found a way that worked.
