The timeline feature on the cam-pan-v3 sd card as storage is really difficult to use. You have to be very precise to make the timeline on the exact spot on the small green circle with a hand symbol in the middle. Maybe just add a feature that when you tap the small green circle with the hand in the middle, it brings up the motion events, which will make it much easier to view recorded events on the timeline. Or when using the red line in the timeline feature to move to a different time, make it stop at the motion events that it recorded since it is really difficult to make the red timeline stop at the exact green circle motion events. Thanks!!
Related topics
| Topic | Replies | Views | Activity | |
| Timeline is a waste of time | 2 | 403 | January 13, 2023 | |
| Timelapse with movement, save as images, neverending | 1 | 428 | January 17, 2023 | |
| Multi-Cam Timeline: How do YOU use it? | 102 | 1268 | September 10, 2025 | |
| Motion on the timeline | 7 | 1267 | May 24, 2020 | |
| Cam Pan v4 - Please add Time-Lapse functionality | 23 | 646 | December 29, 2025 |
