I have a Litter Robot 2, which is an expensive cat litter box that’s totally worth the money, but they now have newer units that connect to the internet and they have an app to reset the box. Their app allows you to reset the device if there’s a fault. These units are very expensive, so if your old Litter Robot 2 still works fine and you want the new functionality you can use a Sensor and Plug to alert you if the globe doesn’t reset to the right position and then, using your Wyse plug, you can power cycle the litter robot. FYI: The newer unit’s app gives a little more functionality, but mainy you want to know if there’s a fault and be able to reboot it, which this will accomplish.
Related topics
| Topic | Replies | Views | Activity | |
| Add functionality to your older Litter Robot | 1 | 523 | December 13, 2019 | |
| Spare, substitute, alternate, makeshift reset key for Wyze sensors | 0 | 377 | May 26, 2020 | |
| Cat litter self cleaner | 4 | 828 | July 7, 2022 | |
| Wyze Robot - Always in CLEANING | 65 | 2987 | January 19, 2021 | |
| Robot Vac will not connect | 46 | 2587 | February 12, 2021 |
