Link wyze bulbs
O.k. here’s an idea that just takes some tweaking in the app - add the ability to link bulbs so they are controlled simultaneously. Basically if you have a fixture that uses two bulbs, it would be great to be able to link two bulbs together so one adjustment and/or setting controls both bulbs simultaneously.
@bomolutra, the bulbs can already be placed in a group, and controlled together in that group. Please see the Wyze Support pages in the bulb section.
Yeah I figured it out ten minutes after sending the post. I have four bulbs set up with two of them grouped and they’re working perfectly - very happy with them. Even on a switched fixture, turn on the switch and they come on at the setting they were at when you switched them off and reconnect to wifi ready for app control
Awesome, glad you figured it out. :slight_smile:
