Lightbulb Automation
Hi, I’m on Android Wyze app and do see the ‘Automation’ feature but it’s a bit confusing. Here’s all I want to do and maybe I’m just not understanding the UI very well. When I’m out, I just want my lights to all turn on a certain time and turn off a certain time every day.
In the custom schedule that I finally got to, I can see the option to “Turn On” or “Turn On for”. I basically want it to just turn on between say 6pm to 11:30pm. So I do Turn on for 5 hrs which is not an option since it maxes out at 60 minutes.
How would I schedule this? Just put a start time of 6pm and an end time of 11:30pm? Would that turn off all the lights?
Welcome to the Forum, @dt282828! :wave:
Yes, and yes. Use the “Turn on” Action in this case, not the “Turn on for” Action. You should be able to apply the Action to individual lighting devices or to lighting groups. Once you do that and set both a Start Time and End Time for the schedule, the Action in the DO section on your Create Automation screen should show a “(Turn off at End Time)” line.
Thank you so much! I did not even notice the “Turn off at the end” label.
You’re welcome! That additional label is easy to miss.
