License Plate Reader Integration
Will Wyze support integration with license plate reader systems, like https://platerecognizer.com ?
Wyze does not appear in the current list of supported cameras:
https://platerecognizer.com/integrations/
This would be extremely useful.
It is likely that ANY software on that page will work with a Wyze V2 or V3 with forever-beta RTSP firmware.
I think you may find the resolution on the Wyze cams isn’t sufficient to actually read the license plate at any distance.
The biggest thing is to incorporate a better zoom maybe 5-6x and higher FPS like 45-60. Then you can pull it off.
