Lamp socket on 220V
Hi,
I tested the Wyze Lamp Socket on 220V and is working well.
Disclaimer: while I’m using it with no problems, please be careful anyway as I didn’t find out how to open it without damaging the plastic case to check the switching power supply components like I did with other products to be 100% sure.
Hope it helps!
Still working?
Yes!
Still working? I just have the same doubt and problem… want to connect the socket to a 220V area.
As well, did you use the output to connect the camera? it works also?
Yes, it works ok!
Hi Edu,
Thanks for answering.
To be clear - Both? the socket for bulb and the usb output for the cam?
Yes, it is dual voltage, the USB and the lamp is working fine at 220v 50hz
