Lamp is calling for help
My Wyze lamp just started flashing SOS.
Something was resting on the button lol
@jacobwhite Welcome to the forums! It sounds like the remote button was calling for help. :wink:
Glad you found the solution. :+1:
If you hold the dimmer switch down for five seconds it will start the morse code SOS and will continue until you push the button again or a power failure occurs.
