Have Wyze cams control smart plugs Kasa
Would that not work with IFTTT?
IFTTT should work if you just want to turn a plug off or on if motion is detected. Cameras can trigger an action when they detect motion, sound, CO2, or smoke:
IFTTT definitely works. I do it with mine.
I have Smartthings do it via IFTTT using a virtual switch and a webCoRE piston timer. It’s pretty convoluted, but it works.
