Simple
November 15, 2020, 12:52am
Is Wyze sideloading updates to the beta apps?
I notice I am getting prompted for login and have seen this with my Scout Alarm when they have sideloaded an update to the app.
That being said… I can’t access my cameras on multiple apps. I get a login screen but once I enter the MFA code it just takes me back to login
IOS 2.15.31 (2)
Simple
November 15, 2020, 1:01am
Wyze offline? On a 3rd device rolled back to stock app and got problem connection to server. I guess I will try my failover ISP
Simple
November 15, 2020, 1:02am
Nope… doesn’t work on Frontier either
If you’re having problems logging into your account it’s most likely this.
3:34 PM PT - We are working to resolve the cause of people being logged out of the Wyze app and/or having difficulty logging back in as well as the integrations not working properly. We’ll share more information as we receive it and apologize for the trouble.
11/14/20 9:48 PM PT - Our metrics are looking good and we’ve worked our way through the backlog of status updates and notifications. We appreciate your patience through this process. If you are still having trouble with your Wyze devices or app, please contact Wyze Customer Support .
8:24 PM PT - Working through the backlog of device events from during the outage has taken some more time than initially expected. We now estimate that this will be concluded in about half an hour. In the meantime, …
Simple
November 15, 2020, 1:07am
3rd ISP at another property with Bluestacks and no go
Simple
I see they are having issues
Roald
November 15, 2020, 2:48am
Everything looks like it’s returned to normal at my end… From over an hour ago… Knock on wood
