Is V3 Spotlight compatible with Cam Pan?
Can I use power cables that comes with V3 Spotlight to power Cam Pan and use the Spotlight with it?
no it is not. currently the interface is only programmed with the V3. and with the pan cam not having the starlight sensor it wouldn’t be terribly effective. maybe in the future they will include the starlight sensor with ALL of the camera models which would them give them reason to build in compatibility ![]()
Hello, @SussexHome…
Welcome to the Community.
Unfortunately the V3 Spotlight Kit can only be used with the Wyze Cam V3.
I found this post in the Help Center (screen shot below)
Thanks all
You’re welcome @SussexHome.
Bam, are you talking about using the cam pan v3 as the main camera or as the extra one that you can plug into the back of cam v3 spotlight…
