Is there a way to remap just one room?
I moved furniture around in the livingroom. Is there a wsy to remap just the one room for my robot vacuum?
I’ve run into the same issue after rearranging furniture in my daughter’s room. I tried selecting her room for a regular clean, but it skipped the areas where bins used to be under the bed—basically sticking to the old map. Then I used the Spot Cleaning feature and highlighted the entire room, and that actually worked—it cleaned the whole surface, including the missed spots. I ran it a third time hoping it would update the map, but no luck there.
So from what I’ve seen, you can’t remap just one room directly, at least not with the current app setup. If you need a full clean despite the outdated map, use Spot Cleaning on the whole room—it overrides the saved layout and hits everything.
Is there a way to re-map a single room with the Robot vacuum? I don’t want to re-map my entire house, I just have a single room that needs to be re-mapped.
Thanks
