Is the Wyze cam v4 Compatible with the light socket?
Lamp socket? Yep!
I have the v4 and a new light socket - but the setup gets to the point of scanning a barcode and then never scans it. I suspect the v3 uses the barcode to get the setup, but the v4 uses bluetooth - and the app needs an update…
UPDATE - Rather than adding the light socket as a new device, If you plugin the V4 to the socket and add the V4 as a new device directly (rather than adding the light socket), then it automatically recognizes that it is plugged into the socket and allows the socket settings to be accessed via the V4 settings area.
(whew)
