– Added alert video thumbnails
That is nice!
– Added WiFi signal strength in Device Info
Works. Curious what the lowest number is for reliable operation. I see it does not very far to come off of 100%
– Added double tap zoom
Very nice!
– Added ‘show Wyze logo’ toggle
It works. I don't mind the logo being there, but I'm sure there are those that don't want it there.
– Added 360p option for slow internet connection
Should be very handy for low bandwidth users. Tried all three and the bandwidth went down quite a bit with the low res. I was watching something that was not moving at all, and could not see any difference in the video. Then tried it on a different camera that had my two flags flying in the breeze. The video quality was very obviously worse (as expected).
Great question! So the tasks only turn motion alert on or off. If the motion alert is on, it will send alerts based on the alert schedule you set.
For example, your alert schedule is from 8am to 6pm. If you have a task that turns off motion alert at 12pm, then you won’t get motion alerts at all. Also, if you have another task that turns on motion alert at 6am, it won’t send motion alerts until 8am. Hope it makes sense!
When you say previews are you referring to the thumbnail images for alert videos? If so what version of camera are you using, as well as the firmware version for that camera? Thanks!
