I want to be able to drag and drop both of the other cameras I have three and it won't let me I will drag it but it won't stay
I am trying to look at events on all three cameras at the same time and it’s only showing me one and so I try to drag and drop the other cameras into this little grid and it won’t work they will move but they won’t stay what am I doing wrong
In the events tab you hit the funnel icon and select the cams you want to see. Not really sure what you’re describing with the drag and drop and grid etc.
I think the OP wants to view multi cam events at the same time which is not possible. The only way to do that is in the monitoring tab.
Honestly I can’t tell what they want to do. Not sure what grid…. Wonder if this is webview or something.
Monitoring > Multi-cam Timeline > Sort Cameras > Drag and Drop
Ah, yeah if it would allow viewing of the SD cards at the same time I’d potentially use that, but with just a still frame I’ve found it pretty useless. I guess subscribers get synchronized video events there? For live view I prefer just using full screen cam groups.
Just tested and going into the edit page lets me move cams around however I want.
Maybe OP isn’t seeing that you can swipe the view back and forth between single cam and multi cams? If the event isn’t on all 4 cams, it obviously won’t show all 4….
I think the OP needs to post some screenshots or a screen recording for us to know what they’re trying to accomplish.
