How to check Asus Routers - Disable "Airtime Fairness"
I have 17 wyze cameras, the 2 latest pan cam v2 cameras keep going offline. I power cycle them they work for a day then go offline again. They are connected via usb to 2 wyze floodlights.
I have another pan v2 hooked up the same way to another wyze floodlight and it is stable.
I may try and disable this setting to see if it helps, but it sounds to me like this is a wifi setting on the asus router and would not make a difference.
