At working hours when there are so many movement and don’t want to record.
So, please tell me how can i deactivate the Wyze Motion sensor at day time
Setup a scedule between the hours you want for motion the whole day video will still be available in the cloud I use the events to view the video in the 5 minute dead times to view while the camera is timing out for the reset of the motion detection.
Wayne
I think they are talking about the motion sensor, which doesn’t have a normal schedule.
The way you schedule the motion sensor is to create a shortcut that turns motion detection on that device off, create one that turns it on, then apply schedules to those shortcuts to create your start and stop times.
