Home View / re-organization
Is there a way to re-organize your devices within your home screen?
Welcome to the community @bir.wade
If you are talking about the App, yes you can.
  • Start the App
  • On the Home Screen tap on the Pencil in the Top Right Portion of the screen
  • Select Edit Devices
  • Touch and hold the two lines to the right of the devices and drag them up or down. Put them in the order you would like them in.
  • When Done, tap on Done in the top right and it will save
