I can order the home monitoring and cameras at the same time but not the V3 camera. The home monitoring comes with Cam Plus which is needed to get a V3 camera but I cannot get one at the same time or add it to the same cart separately.
Is there some way to make this order or do I need to do two orders which seems nonsensical?
Thanks
Is your Cam Plus subscription active? I would assume that the plan with the Home Monitoring System would not start until you activate the system?
It seems like there is a chicken and egg situation here but it seems odd that the requirement is part of what you are getting with home monitoring and yet you cannot get the camera that requires the feature you are getting with that product.
Weird.
