I have central AC/Heating in an apartment. Looks like this old thermostat does not have a C wire. And I’m not sure where the furnace is to hookup this c wire adaptor. I assume that furnace is shared throughout the complex? Would not want to mess with it. I ordered the “Wasserstein 24V Transformer” that says it works with wyze. How would I configure this? What terminals should I select and tell the wyze app? Right now I only have R / W / G / Y. Thanks in advance.
wilb
You can plug your 24v adapter pins to C and RH on your wyze tstat unit.
Related topics
| Topic | Replies | Views | Activity | |
| Wyze thermostat and 24v adapter | 6 | 1921 | February 3, 2021 | |
| Thermostat Wiring Problem - Help Needed | 9 | 1489 | March 24, 2021 | |
| Old Gas Furnace with Wall Adapter for C Wire | 9 | 1365 | June 13, 2021 | |
| Wyze Thermostat 24 volt power adapter question | 6 | 1400 | September 25, 2025 | |
| Thermostat Power supply | 6 | 1646 | January 31, 2021 |
