Google Home/Assistant Integration
…and I’m also interested in Google Assistant integration. In particular, I’d really love it if I could ask for the state of a contact sensor.
If you want to be part of it, please send me the email address you use for Google Home in a message!
@russgoog, we are going to be working on Wyze Sense integration with Google Home soon. :slight_smile:
Hi! I’d also love to have access to the Google Assistant integration!
Great! Please send me a message with your Google Home email address. :slight_smile:
Can I please enroll in the Google Assistant integration program? I have a Google Home Hub and several Google Home Mini’s as well as a v2 Wyze Cam. Thanks
Same instructions for you! Please send me that message. :slight_smile:
Sent!
Hi I want in. But i dont seem to be able to send you a message.
You should be able to now!
Superb! How can I test it? Do I have to set up something in google home or wyze app?
Hi, may I be enrolled in the Google assistant program?
Thanks
how do i set it up?? any instructions?? thank you😅
Here’s the link to the instructions! Though you need to wait to be added first. :slight_smile:
@dariomanchia, please send me your Google Home email in a message.
would it be possible to also get into the beta?
Yup! Just send me a message. :slight_smile:
Hi, not sure if I need the email but I keep getting this error any advice?
can i still be part of google home.??
Have been following this thread for awhile. Is it still possible to get on the integration beta?
I would like to join. How do I send a message to you?
Would like to do beta too. Tho I believe account to new since just made.
