- Wyze Battery Cam Pro
- Firmware: 1.4.2.3615
- 256GB SanDisk Ultra MicroSDXC UHS-1 (Speed up to 150 MB/s) (Class 10 rating)
I have four Battery Camera Pros, all four recognize a Wyze branded 32 GB MicroSD card. I’m working with two of the four cameras for this issue (haven’t tried the other two as they are in service)
If I remove the 32 GB MicroSD, and insert the 256GB SanDisk Ultra MicroSDXC UHS-1, the two camera’s I’m trying to initially setup, do not recognize the card has been installed.
If I re-insert the Wyze 32 GB MicroSD, the two camera’s immediately recognize the 32 GB MicroSD.
If I select “Eject MicroSD Card”, then physically eject the 32 GB card, then insert the 256GB Sandisk MicroSDXC card, The 256 GB card is recognized, but shows as 0G/0G and the “Format” button is available.
I select Format, and it then displays as 0.00G/29.54G. odd…
I back out of that, and select “Manage MicroSD Card” again and it’s now showing 0.00G/238.30G
All is well, or so I thought.
I went back to check that both Camera’s were seeing the 256GB SanDisk Ultra MicroSDXC and sadly I was back to: “no microSD card found” on both cameras.
I’ve tried formatting both 256GB SanDisk Ultra MicroSDXC cards to FAT32 with free version of AOMEI Partition Assistant Standard , and also tried formatting with the SD Memory Card Formatter for Windows and still no love from the Wyze Battery Cam Pro with these 256GB SanDisk Ultra MicroSDXC UHS-1 cards.
Am I doing something wrong, or is this a known issue?
SJ
