Force event alerts
Don’t shoot me if requested already. I just got here, did a search and didn’t find this. My multiple Cam Pans are scheduled to alert me from time A to time B. I want to be able to manually force on monitoring for ALL my cams if I leave before time A or force it off when I arrive before time B. I want the ON toggle to override my schedule settings but not replace them. Thanks.
I have not tried this so I am not sure if it will actually work. What I would try is adding a shortcut that turns on monitoring and one that turns it off. In theory those shortcuts should override the schedule since for example, you turn on monitoring prior to the scheduled time when the schedule comes around it just tries to turn on what is already on. Theory works but again I have not actually tried it.
I use override shortcuts every day (and night) on multiple cams and groups of cams with applied schedules. Works exactly as you described. :+1:t2:
