False motion notifications every time cameras turn on
I’ve created an “Arm” automation which turns on all my Wyze cameras. As soon as I press “Arm”, I immediately get notifications from all the cameras, despite there not being any motion. After the initial notifications, the cameras behave and only send notifications when there is actual motion. We do not want the cameras running 24/7, only when we press “Arm”. When we press “Arm”, any motion detected by the cameras triggers an audible alarm, so the startup false detection sets off the siren.
Why are the cameras “detecting motion” upon startup? Can this false detection be prevented?
Cameras are v3
Haven’t had that with any of my cameras. Are you using “turn on the camera” or “enable motion detection”? Maybe try the other one from what you’re using.
With the Panv3 turning off the cam puts it in privacy mode. I guess coming out of that mode could have it detect motion as it moves back into position, but when I’ve manually put mine into privacy mode (to access SD card etc) it has never logged an event coming out of it.
Maybe have your automation both disable motion detection and turn off the camera, then when you arm it, have it turn on the camera then enable motion detection. Maybe that would be enough to prevent it.
Pressing “Arm”
  1. Turns on cameras
  2. Turns on motion detection
  3. Turns on notifications
Pressing “Disarm”
  1. Turns off camera
  2. Turns off motion detection
  3. Turns off notifications
I think you’re right, when the camera is turned on (out of privacy mode) it moves around for a few seconds before it “settles in” to one spot. I think the moving it what’s immediately triggering a notification. I wish there was a way to delay the motion detection for the first 10 seconds after the camera turns on (or some similar rule). As mine are currently setup, as soon as I press “Arm” my siren alarm starts going off…not very workable.
In that case try the opposite, just have it turn them off and on, not the other things.
When the camera is off, the other two things are off also, so shouldn’t need to disable them.
If manually putting the camera in and out of privacy mode doesn’t cause it, then an automation with only “on” and 'off" should work the same.
So you’re saying my automations should be…
Press Arm → Camera turns on (but nothing else happens)
Press Disarm → Camera turns off (but nothing else happens)
Is that what you’re saying? If so, how will that trigger an alarm or notification?
Yes, try that.
I thought you didn’t want it to do those things when you arm it? Turning the camera off and on does not change any other settings, whatever you had set for notifications and alarm will still be there when you turn it back on (they are paused while it is off automatically).
I DO want it to notify me and trigger an alarm if motion is detected, but only if motion is ACTUALLY present (instead of a false positive). The problem described in my first post is that whenever I press “Arm” and the 3 rules I stated above are enabled, the camera is immediately telling me there’s motion when there’s NOT actually any motion. I want all of my 3 rules to exist, but to not receive a notification of motion when there’s actually NO motion. Does that make sense?
Change your automation to simply turn the camera on and off. Your settings for motion detection and alarm will automatically resume when the camera turns on. I’m thinking that the turning off and on of those features is confusing it.
When you turn the camera off, it also automatically turns off motion, notifications, and alarm. When you turn the camera back on, it turns those back on. So your automation is making it do it twice.
Appreciate the input, but I don’t think that will work for my application. I don’t ALWAYS want motion to trigger notifications and an alarm. I only want that to happen when “Arm” is pressed. For example, if randomly during the day I want to turn on the camera and see what’s happing inside the house with my family, I don’t want motion detected during this time to trigger any alarms and notifications. So I don’t ALWAYS want motion to trigger notifications/alarm, and instead only want motion to trigger alarms/notifications when “Arm” is pressed. My “default” is that notifications and alarm are OFF and are only turned ON when “Arm” is pressed, and again turned OFF when “Disarm” is pressed.
OK, gotcha. Well you could test it just to see if that is the issue or not. If so we may be able to think up another workaround.
The startup movement is very likely it. Coming out of privacy mode the camera sweeps back to its preset, and the motion detector sees the whole scene change, so it fires before it settles.
The simplest fix is to stagger it so the alarm parts only turn on after the camera has parked. Split Arm into two steps: the first one only turns the cameras on, and the second one turns on motion detection and notifications. If your app shows a delay option when you add actions to the rule, put a 1 minute delay between the camera on action and the other two. If it doesn’t, make it two shortcuts and press the second one about 10 seconds after the first. Disarm can stay as it is.
I confirmed the camera movement at startup is triggering the motion sensors. So I created rules which first turn the cameras on, then 20 seconds later turn the motion detection on. The cameras do not have any “time delay” options. My first attempt was to create two different push button automations “Arm Phase 1” (turns on cameras) and “Arm Phase 2” (turns on motion detection and notifications) and wait 20 seconds between pressing each automation. This worked but meant I had to wait 20 seconds which was annoying. In my second attempt I remembered that Wyze plugs do have some “time delay” features, so I created the following automations:
Tap “Arm” Shortcut:
  1. Turns on cameras
  2. Turns on Wyze Plug
2nd Automation Rule:
If Wyze Plug is on for 20 seconds → then turn on camera motion detection and notifications
This works and now I only receive motion detection notifications when there is ACTUALLY motion!
Yeah a lot of people take advantage of wyze smart plugs and bulbs in automations for tricks like that.
I guess when you turn on the other stuff in the same automation, it happens too quickly before the cam has fully moved back into normal position. Would be nice to have a “wait” function in the automations.
Welcome to the Forum, @james.sharpin! :wave:
I think you’ve probably found the most practical solution for now (at least if you’re trying to remain within the Wyze ecosystem), and I’d add that you may want to include something like a “trigger reset” function to your second Automation by just adding the “Turn off” Action to your Plug or by creating a third Device & Service Trigger Automation:
  • IF
    • Plug
      • Has been on for 00:00:30
  • DO
    • Plug
      • Turn off
That way your Plug is ready to go the next time you “Arm”. You may already be doing this.
Good point, as I’ve also used Bulb Color for this sort of thing, which can be a helpful indicator in addition to serving as a trigger. Plug Outdoor is good for this, as well, as a 2-for-1 logical switch (just because you have two potential triggers in a single device).
There’s an existing request for this:
As with any Wishlist topic, you can visit that one to click or tap the Vote button above the initial post and share your ideas and use cases in the comments to show your support for the product and feature request/suggestions that are important to you.
Some additional discussion about this is also here:
