Once set up,
is anyone else interested in being able to try to do a factory reset of a cam from a menu rather than push button…
my cams are installed up and away. I would much prefer to select from a menu if I still have access that might work instead of up the ladder, or across tiwn, …
. I have cams that are getting error codes such as -67 or -90 and seem to still have access.
If you do a factory reset you are going to need access to them to set them up again which means rescanning the QR code for networking.
I’m with Bill on that one. If you factory reset a camera you would have to physically access it in order to do the setup procedure anyway - so what’s to be gained by a factory reset from the app?
