Events Beyond 24 Hrs Ago
EVENTS: Why can’t I view events beyond 24 hours ago? And yes there’s an SD card in the camera
Welcome @colleen_wright
Viewing events from the event page is different than viewing the SD Card. When on the event page, you simply tap on the date at the top of the page. Note, this will show events recorded if you have Cam Plus and will save them for 14 days:
When on the SD Card tap on the date and then select which date you would like to view. Note: If set to continuous, you should see everything until the SD Card fills. Then it will restart from the beginning:
