Event recording with no wifi not working - 4.9.4.28
Hello @WyzeGwendolyn !
I recently updated the firmware of my V2 wyze cameras from 4.9.2.52 to 4.9.4.28. I really wanted to be able to use the new feature where IR lights can be turned off in night vision mode.
However, the place where I am using the cameras does not have a wifi which they are able to connect to, and since the upgrade the cameras do not record to the SD card off of wi-fi (I never had any issues with this before).
Is the only solution for now to manually downgrade (flashing) backward, to firmware 4.9.2.52?
I just tried it with one of my 6 cameras and it seems to have worked, it now records to the SD card, I’m just afraid to do it with all of my cameras in case something goes wrong.
Thank you for your help!
