Event Recording length
I have 2 minutes set for event recording on my solar cams. But the events never record for mor than 10 seconds. Usually less than that. What have I not set properly?
Welcome to the Forum, @dlanier0148! :wave:
Without more detail about your settings, expectations, and examples of events you’re capturing, it may be difficult to tell. The bottom of the Event Recording screen, beneath Maximum Video Length, says, “Event videos will end earlier if the motion stops.” Is that what’s happening, or are you trying to generate events that last longer within the Cam’s view, or is something else going on?
Also, how are your Detection Settings set? If the sensitivity is low, then I wonder if the camera thinks motion has ceased (so it can stop recording) even though there may still be some motion within the camera’s view. If you’re using a Detection Zone, then that could be an additional confounding variable.
I know that on my solar pan cams, if someone stops to take a breath, the recording will end. If motion stops there should be some extended time (i.e. 5 or 10 seconds) for motion to start again before ending the recording!
