On the Wyze Cam Floodlight Pro, can you disable the dusk to dawn and use the flood lights and camera with just motion detection?
There are two Lighting settings that can be scheduled from Sunset to Sunrise (Dusk to Dawn): Ambient Lighting and Motion Activation.
For each of these, you have the option to customize that schedule away from the Sunset to Sunrise default by scheduling it for up to 59 minutes before or after Sunrise\Sunset; or you can customize your own Start and End times.
If you wanted either of these to operate constantly 24\7, you can set the schedule to run from 12:01 AM to 12:00 AM.
Thank you very much
