Download from SD card
Has anyone found a way to download the video content from the v3 SD card over wifi?
Unfortunately, we have two options. The first one could be done while connected to your wifi network.
  1. Use playback to record the contents of the uSD card (not very realistic as playback is real time)
  2. Pull the uSD card from the camera and copy the data to another device
Unfortunately those are the only two options and I am certain neither of those are what you’re looking for. I would guess if you look through the wish list you will likely find at least one post requesting an ftp or sftp style transfer directly from the cam.
Edit:
I did a quick search and found this wish list item:
Direct access to SD card…
