Hello all, anyone out there know how to connect existing indoor cams to chime with the door bell?
Are you trying to connect a Wyze Video Doorbell V1 to a mechanical chime? That doorbell version doesn’t use the mechanical chime, you bypass it during the install process
Thanks. On my Wyze app under the door bell settings, there is a tab for camera as chime. As I understand it, the existing indoor cams can be programmed to chime when the doorbell is rung.
