Door bell and solar panel
Can you use the solar power unit to charge a battery operated doorbell camera?
Depends what model, you may need a plug adapter. Check the product pages for the model you have and see if it says it can be charged while in use (I suspect it can) in which case just need to make sure the plug type on the panel matches the one on the camera, and get an adapter if not.
