Does motion sensor PIR activate the Wyze Plug or only the bulbs? I want to place a Wyxe PIR sensor at the bottom & Top of the stairs and have some LED light strip plugged in to the Wyze plug so when I go up at night the PIR sensor will activate the Wyze Plug, thus turning on the LED strip light along the stairs, and vice-versa when doing down stairs. Is this possible.?
I hope (and assumed) so !
I just ordered a bunch of plugs so my motion detectors could activate them.
Iāll know shortly, they are arriving soon.
Chas
Yes, absolutely! I use the Wyze motion sensor and contact sensors with my plugs and bulbs. It works great. I open my back door and the lights turn on. I walk in front of the motion sensor and it will turn on the plug or a bulb either one. ![]()
StopICU33 - Thank you. Your help is appreciated⦠![]()
Youāre welcome! ![]()
While youāre here ,⦠I know youāre very experienced and I hope you donāt mind me asking this question here is there a way to have the motion sensors turn on the lights in the evening hours only instead of during daylight hours (a time schedule would be great)?
Thanks
Chas
I donāt mind at all. I do use a time schedule for my bulbs. I have certain bulbs set to tun on with a schedule in the rules. For example, I set a schedule to turn on one bulb at 9 pm and turn off at 11 pm nightly. I have different schedules set for certain days like on the weekend I usually have the porch lights set to turn on around 7 pm. Then they will turn off at my set time or sometimes I set only one schedule to turn on and when I donāt need the light on, I will turn it off manually. Either way it works for me. Hope this helps answer your question.
Thanks for the reply.
I will uses a schedule for the plugs, but I was really looking for a schedule for the motion sensors, so they would not send a signal during the daylight hours.
Chas
Very Cool I did not know that could be done⦠I just ordered 2 of the PIR Sensor and a set of plugs. For the top and Bottom of my stairs. So I can set the plugs via ārulesā to only ālistenā to the PIR sensor between 8:00pm & 6:00am (what itās dark) so they donāt turn on the light when not needed⦠Very Cool⦠Thank you Again StopICU33ā¦
I apologize. I was in a hurry and totally missed that.
The motion sensor will trigger a bulb if it detects motion, but I havenāt seen any where in the rules that allow it to work just certain hours like you mentioned. I will ask to be sure.
According to the roadmap, combining a schedule and event is in testing at the moment.
It is currently available in beta only. So it is coming in the near future.
Hey @chasjabber, what @StopICU33 stated is correct, being able to schedule rules based on time of day is currently in Beta. for me it has worked flawlessly thus far. I have a contact sensor in my garage so when I get home in the mornings and open the door, it turns on 3 plugs in my house so I have lights already on. I have it set so that it wonāt do that behavior anytime other than morning when the sun is still down. I had to actually look up sunrise times for this as it is not native in the app. not that big of a job though. I havenāt had that malfunction or not work once and honestly I didnāt realize how much I would use that feature. other than a misspelling within the app I havenāt see much in the way of compliants/ bugs for this Beta, I could see it becoming public reasonably soon.
Perfect BAM, This is what I was hoping for. Since Wyze said itās a 12 month battery in the sensor myself is not concerned about the sensor just the plug being able to do what you have set up.
Thank you for the explanation.
A little reading for ya
Glad I could help
on the upside you can always revert back to the production version too if youāre not happy being a beta tester
OK⦠my request to join the Facebook beta group is pending. I just got in four plugs and a couple bulbs today just in time for testing thanks Chas
Just make sure when you signed up for the Facebook Beta group that you answer all the required questions, I believe there are a total of 4 last I checked.
Thanks, I did that this afternoon and it said request pending.
I looked again a few minutes ago (8pm EDT) and it said ājoin groupā, so I submitted a request again.
In the meantime Iām using the Beta app nowā¦
Chas
