Docker-Wyze-Bridge redeaux
It’s alive!
I’ve completely rewritten my version of Docker Wyze Bridge. It’s now a total rewrite in Go, uses the go2rtc sidecar for WebRTC and TUTK cameras, uses internal proxy for GWell cameras, and even talks to my Video Doorbell Pro.
It has Metrics, MQTT, Prometheus, and pretty much every other shiny bit.
If anyone wants to play with it, grab 4.2.2 or later from GitHub - IDisposable/docker-wyze-bridge: WebRTC/RTSP/RTMP/LL-HLS bridge for Wyze cams in a docker container · GitHub
Wow! People were dying to have a single docker supporting both TUTK and Gwell! Well done. Not to mention all the extra benefits. I’m going to bookmark this.
I actually considered eventually pointing my open claw or Claude code to both the tutk docker and Gwell docker and tell it to combine them into one. Looks like you already did it. :+1:
I’m getting a manifest not found error when I try to deploy.
There is no mention of the Window Cam in the supported camera list. Is it something that might work and I just need to test it or something that definitely won’t work?
