Distance Option on Outdoor Battery Cam
I need an option. I use several Outdoor Battery Cams, but the viewable range is a bit short. What I would like to see is a Battery Cam with the same viewable range as the OG Telephoto.
That’s a hardware request. You can add it to the wishlist that you want a telephoto battery cam but honestly it seems unlikely. There are lenses you can attach over cameras to attempt to change the zoom, and some have even disassembled cameras and replaced the lenses. But your easiest bet might be to get an OG-TEL and run it off a USB battery bank.
Hi There dave27,
Thanks for the suggestion. Sorry about the misclassification. I will revisit the installation and see if this will work.
Thanks again!
