Can anyone explain all the difference like what you get or don’t get by using cam plus ans or an sd card or no cam plus and sd card.
No subscription… No SD Card … That means you just get motion events in 12 sec increments with 5 minutes between captures. Everything is stored on the cloud and it is kept for 14 days… You can only go back and look at motion events. Nothing else. You will ONLY receive motion notifications. With a 5 minute cooldown between alerts.
No subscription… SD Card. This still means you just get motion events in 12 sec increments with 5 minutes between captures. Everything is stored on the cloud and it is kept for 14 days… You also can have continuous recording going that will record about 3 days worth of video at HD. You can scroll back anywhere in that sliding window to review video. After that, you will only be able to see the motion events (12 sec videos). Same thing on alerts… ONLY motion and 5 minute cooldown.
Cam Plus with SD Card. Cam Plus allows your cameras to ONLY alert you when they see a Person, Vehicle, or Package. This is essential for outdoor cameras that get tricked by leaves blowing by or shadows. It allows you to receive notifications for ONLY those events. You will no longer get notifications for “motion”. It is specific. When events are recorded in the cloud, they are recorded for as long as the event is occurring. So your cloud storage is not limited to 12 second clips… it could be 2 minute videos depending on what is happening. And there is no cooldown. If something happens 30 seconds after it stopped the last event. It will begin recording again. You can also use the local storage of the SD to go back to the recent past but always remembering it only stores about 3 days worth at HD quality.
Hope this helps. Hard to not write a novel sometimes.
-Earl
This is excellent thank you’
