How do you delete the videos from the doorbell? Thanks.
I haven’t done it yet, but I believe you would use the events page and select the doorbell there and do it the same as any other cam.
I dont THINK it can be done from the doorbell live view even though you can view the videos from there as well.
If you are watching the events via the doorbell viewer and not the event tab, if you hit the “…”, And then the trash can, that should delete it. I am on a beta app so it may not look exactly like yours but I’d think it be there.
You go to the main page and select cameras. Then, you can select all. Then, delete. Thanks.
The above answers are no longer valid. Over the last two days, I have had two recording events shown on my doorcam page. But when I try to replay them, so I can delete them I keep getting a dialog that says “the event failed to load. Please try again.” And when I go to the Events page it claims there are no events.
So the question now becomes “how do I reset my camera view page to get rid of those two, false camera events?”
