Deleting Cloud Event clips for a given day
when deleting cloud clips for a given day, if there are a lot of clips, and you wish to delete ALL of them at once, and you do select “Delete All”, there seems to be a limit on the number of clips it deletes such that you need to do this several times to get all of them - Has any one else encountered this, and is it a bug?
You must scroll down the page to ‘load’ all of the events before you select all and delete. The Events page only loads something like 20 events at a time instead of loading everything every time you go to the Events page. Not a bug.
Ideally, one should be able to delete the day’s events without having to wait for that screen to fully load. Look at the prior options screen, “Filter”, “Delete Events”, “Cancel”. There’s more than enough space to add, “Delete All Events”. That’s an easy software fix, it’s just refactoring existing code.
